help with my spark plug choice
#31
Look at the post above yours concerning E3s. There have been several try them and had to remove them in just a few thousand miles.
#33
The bold part makes no sense. These trucks have a lock up convertor. Therefore RPM X GEAR RATIO= MPH.
#34
on
#35
#38
BTW, I know your only suppose to put the compound on the electrode shaft but have any of you used it on the threads of the spark plugs?
I just bought my sp515 today at Oreilly's for 7.99 each, but they didn't have the nickel anti-seize compound. Is it really necessary to have the one piece deepsocket with built in extension? I figured I would use some 3m electrical tape on the socket to the extension to prevent seperation of the two tools. Have any of you had a problem with the socket coming off inside the well?
#39
Napa auto parts sells an 8oz bottle for around $21.49 instead of the 16oz bottle for $38.49. Too bad they don't a 1oz tube in the nickel like the other compounds.
#40
#41
I went with the e3 3.70 and they lasted 3 weeks until a misfire on 2 cylinders...champions went in and were great for a few thousand miles and now seems like it is on 7 cylinders...no power and slight rough idle...
I bought msd coils but was waitng for better weather to install...
now I think I wil spend the $$$ for the Brisk plugs...
not meaning to ofend...but after the hassle of removing the stock plugs
with only 40k there is no way I would install motorcrap or autolite 2 pc plugs...I agree the truck ran great with them in but why would I want to spend another weekend changing plugs because some fat cat suit thinks it's not his problem to fix...
I found a place selling the Brisk plugs for under $140/8...
I can pull the champions out install them and the new coils in about an hour.
leaving me the rest of the weekend to do as I wish and knowing if I choose/need to take the plugs out I can do so without issue..priceless
There might be a reason the 2 part plugs are so much cheaper than the others...
my $.02
my $.02
#43
#44
RPM's
I'm still getting better mileage both around town and on the highway.
Paul
#45
my $.02
my $.02
