Plug change at 104,xxx miles '04 5.4
Plug change at 104,xxx miles '04 5.4 - success
Coming back from Lexington on Sunday, it started misfiring badly and threw code P0303 (thank you ScanGauge) and I had to nurse it home. Tried switching coils to see if it followed and it did not. I have the extraction tool on the way and the plugs sitting in my garage. Right now I'm going to focus on plug #3 and hope to get it running well enough till it warms up a little. It's 18 degrees out now and don't have a place big enough to get it warm. Meanwhile my front left window regulator went out again and the window is taped up. Wish me luck.
Personally - I think 1/4 is too much. Likley already broken at that point.
When I see 'crack' I think just enough to break the gas seal is plenty ( with a tapered plug seat it will not be much of a rotation at all ).
The carb cleaner will then capillary all by itself given enough time.
Good luck, OP. Hope it's the plug and not the injector.
MGD
MGD
No hostility there, it's all good. I was just in a hurry before work. I see your point though.
I simply broke the plug loose. It's still soaking.
I tried a new coil on it and the misfire was a little less frequent so hopefully it's the plug. It's due for plugs anyway. Even if it's not the plug, I'll still fix it. After a new exhaust manifold, two new window regulators and now this I still love this truck.
Could be a good thing I have a three day weekend.
MGD, could a misfire like symptom and a misfire trouble code actually be a faulty injector? I had codes p0303 and p0316.
Plug is out!
Now I just need to roll the motor over a few times to get that carb cleaner out.
What I find odd is that the end of the plug looks different.
Edit:
I checked Oriley's site and that is the way both of the motorcraft plugs look.
It's all buttoned up and running smoothly. Just waiting on the ice to melt off before going on a test drive.
Edit:
