High pitch whistling
Hey guys, I have a 2005 f150 fx4 with about 90k on it. Now this only happens when its ten degrees or colder but when i first start driving my truck i get a very high pitch sound coming from the front of the truck. It varies with the rpms and only does it when the truck is colder then the the half mark. My alternator isn't bad i just had it checked and none of the pulleys or the belts are making this noise. Any ideas? Thank you for your help.
If you have a chance, take off the serpentine belt and spin the alternator / pulleys by hand and see if you notice any noises.
I had an 02 sporttrac that did the exact same thing. I lived with it one winter then took it to a reputable alternator shop who replaced a thrust washer and 1 or 2 bearings. Cost me like $60, but the alternator was fine otherwise and a new one was close to $300....
My 07 FX4 did the same thing with about 7k the first 0 day a few years ago...
I believe it was the water pump pulley bearing or some pulley bearing for sure...can't seem to find paperwork...warranty covered it...
it was so loud I could even hear it in the house when I remote started it in the driveway!!!...I remember the dealer was not able to hear it the first time I took it because it was not cold enough!!!..they thought I was nuts...
Mine too... I'll live with the cold whistle until something gives. More anoying is the driver's hand crank window freezing shut (comes loose from the regulator) when cold.
Dan J, That's for sure! A friend helped me rework my wife's old Chevette alternator. We replaced a couple bad capacitors and all the brushes and "VIOLA!", like new.
