Spark plug change, now runs like crap please help
I changed the plugs in my 2007 F150 5.4 L with 65k miles. All 8 plugs came out great with no brakeage. So i thought everything was good. I put the new plugs (E3 plugs E3.70) in... had a lit of trouble with the far cylinder on the passenger side but eventually got it. Put the coil plugs back on and everything.
Now it idles really rough, shaking the truck, i can hear a "POW" every couple of beats out of the tail pipe ( not really loud) and it hesitates on acceleration.
Any ideas of where to start looking. Please help... we have a trip scheduled in 2 days.
https://www.f150online.com/forums/ot...ark-plugs.html
My truck ran ok, I figured I change them just for maintenance put the E3 in it ran rough. Went to advance auto parts they carry the updated plugs (motorcraft).I tried looking to see if one of the E3 plugs were cracked but I couldn't tell. Truck runs alot better. Ur description is exactly what happened to me. Take them out and inspect them for a crack. Good luck let me know what happens
I had a lot of trouble with the far back cyl on passenger side. I had to use multiple extensions and knuckles and they kept binding. Maybe It felt tight and it really was not tight. I just read that it is ok to remove the computer and bracket. So will remove those and redo that cylinder and see if that fixes it.
Is it possible that if a spark plug is not quite tight enough it will cause this issue? I am just trying to go back through everything i did. That is the only cylinder that gave me any kind of trouble.
You arnte supposed to get grease on the contact spring? Dialectric grease does not interfer with electric signals.
I removed computer and was able to get another turn or two out of the #4 spark plug. Started it up and it runs like a champ so far. I am letting the computer reset now and will go for a test drive in a minute.
