New Christmas goodies...
Got some cruddy(i thought) HID's, PIAA 510's, Infinity Kappa door speakers (front n rear) and a Polk Audio PA660 4ch amp.
heres some pics..
HIDS & PIAA fogs
Polk amp (yeah trucks a mess)
PIAA fogs
ran the wire for the fogs to the hot on the factory fog plug. works perfect. I'll go get some better pics at some point today...had it washed too...
heres some pics..
HIDS & PIAA fogs
PIAA fogs
heres some pics..
HIDS & PIAA fogs
PIAA fogs
heres some pics..
HIDS & PIAA fogs
PIAA fogs
the piaa lights come with a relay. you wire the power for the lights right to the battery and use the hot wire from the factory fogs to pull in the relay. that way when you turn on the fogs with the factory switch it sends power to the piaa relay, thus turning on the new lights. pretty simple to do, just time consuming organizing the wires to look clean. dont forget, if your cutting your factory harness off the use the hot, cut it far enough back that you can always splice it back into play and reverse your mod.
heres some pics..
PIAA fogs
heres some pics..
PIAA fogs
and it is an fx2 grill, and lower. i bought them from someone on here
