Help.
Help.
WTF am I supposed to do? I have 127k on the dash I had all the coils and plugs changed and the fuel filter changed. I am at my wits end today after finding that one of my cops was loose and not seated well, so I tried to tighten the bolt down but to my horror I found the hole was stripped and will not secure the cop, which I fear is causing my truck to buck while under load going up hill or accelerating around 55-60 mph. So how do I use the bolt and get it to secure the cop and stop my truck from running poorly?
I have not thrown any codes, the check engine has not come on, this is whats so frustrating.
At 70k when mine started bucking, it threw no CEL but the computer had stored a cyl #1 random misfire. Changed the plugs and boots and it was gone. Doesn't hurt to check them and see if it's there with no CEL.
I used the term "tap for a bigger bolt" with a friend of mine recently. He actually got a bigger bolt and "tapped" it in with a hammer !!! I guess thinking thats what I meant. I have since learned to just play ignorant and tell him to see a mechanic.
Nitrox
Nitrox
Am I the only one who questions bringing the truck back to the place that stripped the threads in the first place? I wouldnt bring my truck back to that place again!
If you are uncomfortable doing it yourself, I suggest you find a reputable shop and have them do it. You can do it...its not that difficult.
Sometimes I think there should be a lock on the hood .... but then how will they learn? I guess best to let them learn like I did, it's just more expensive knowledge these days.
