spark plug lawsuit
Why is it the consumer that pays??.. If the mechanic is not skilled enough? The consumer did not cause the problem, and the consumer was never made aware of the problem prior to purchase, even though the company was aware of the problem.. Like say,,, they knew in 04-05 and didn't address the problem till when 08? So we have what? at LEAST 2 model years of issues with no word from ford? And now we are told "eh... live with it,,, 'eh... pay the man... Doesn't seem quite right? I bet if this were a GM issue,, there would be more people on this site going total bats$$t...
To me, since ford new they $rewed up.. And yes ,,, they sooo totally knew about it. They should eat the broken plug expenses.. Pretty simple really.. Base price for plug removal,,, 250.00.... Any fees incurred for broken plugs,, billed to FoMoCo. Especially since we are talking about factory certified ford mechanics,,[that should mean they are good enough to remove plugs right"],, should be able to remove them no problem...
So why does the customer get the added expense?
I don't think suing Ford makes any sense in this issue. For the most part, the plug changes are getting done (albeit with a few more dollars out-of-pocket and some extra shop time) but I hardly see this as an issue worth suing over. In my opinion, people who sign up for this class action crap are 90% of the reason we live in such a screwed-up society when it comes to legal issues.....
OK, so I am rounding into 50k miles and from all the talk on here it is making me start to wonder:
Am I gonna notice a difference in changing them out now, or should I wait till the 75k mi maint? I am not doing it myself either way, so gonna pay the dealer to do it wether its now or then.
YOur thoughts?
YOur thoughts?
YOur thoughts?
YOur thoughts?
The instructions for the Lisle tool are pretty weak. They leave out the part about inserting the pusher pin into the tool, before you screw the part in that bottoms out on the guide. It worked well though. Just make sure you thread it in, until it becomes very hard to turn. Don't over-do it though or you will strip the threads. Also, get a deep 15/16ths socket to fit over the nut you need to turn in the last step. You also need a pair of long needle nose, in case one breaks, but the electrode wire is still holding the plug in.
I looked at the gap on the plugs that came out w/o breaking. It looked way out of spec to me. Hardly any electrode left. They could probably go for 100k, but my cold idle is much smoother, now.
I think I dislocated one of my ribs with all of that leaning over the radiator shroud and torqueing. They over-torqued them at the factory.
I think Ford should eat the cost over a certain amount, if the plugs break, too.
There is a writeup in the index of the Articles and How To that shows you how to clean the MAF. Takes about 5-1- minutes, and the cleaner costs about $10.
Too many have gone over 100,000 on the original plugs for that to stand up. I know two or thhree that did not change them till 130,000.
Also, I don't recall them ever advertising that they would go 100,000 before changing. That was just the recommended plug change and taht is not the same as advertising.
