About to place an order
That is unless the experts on this here site tell me otherwise!
http://www.jegs.com/i/Edge+Products/367/15051/10002/-1
http://www.jegs.com/i/Airaid/028/400-740/10002/-1 <<<------ edited
and of couse to of these along with x-pipe minus back 2
cats
http://www.jegs.com/i/Dynomax/289/24215/10002/-1
cats
Skip the Spectre crap even if you want a "CAI" system. I have installed two for friends on a early Tundra and a 01 Chevy. Terrible quality, sub par fit and filters look like junk after a couple months. Either do the Gotts Mod as mentioned or if you want aftermarket look at the Airaid Modular Intake Tube (M.I.T.) similar to the Gotts but cleans up the engine bay.
Yes, but it's the custom tune that makes the difference. Non-custom may mean that you're air-fuel mixture is too lean which is bad for your engine.
well, it might look better in your opinion, BUT since it performs like poo compared to the gotts intake mod take your pic performance or a mod to add to your mod list that will help slow your truck down just so you can beat off whilst reviewing your mod list
you dont have to get the custom tune right away with a gryphon. you can spend 400 on it and drive it without a custom tune, it cmes with the same level 1 2 and 3 tunes on it, then you can get custom ones later. worth the extra 40 bucks. then if you get a cai you can get a custom tune to correct for it and not make it run lean
cats
cats
