your favorite SISO catback exhaust system
#32
I have the MBRP SI/DO that exit behind the rear tires. It's a good system. Very deep sounding. No drone in the cab at cruising speeds. There was some crackling after I would rev it, but it seemed to go away after a short break in period. The only problem I had was trying to get the tips to look level from the back. It's not impossible, but it is hard. I gave up and ended up removing the last section of piping on both sides and just put the tips on from there. So, the exhaust ends right on each side of the spare tire. I think it looks pretty cool having the "clean" look of no tips/pipes showing out the sides. However, you can see the tip from the side of the wheel wells. Not quite as deep sounding, but did gain a little in loudness. Better in my opinion and still have like zero drone.
#34
#36
jesserohr if you can offer any insight as to whats going on id appreciate it. if you go back a page or so i show examples of it.
i was going to do true duals but from what i understand the popping cackaling sound is the nature of those systems.
anyone, what makes the maggie si/so kit so much more expensive? the magnaflow catback has a chambered muffler setup where the mbrp system has a straight through sort of muffler right? going by their measurements on the maggie site, the welded in universal maggie i have is smaller than the one in the catback?
#37
If you're looking for a SI/SO system the 3" catback doesn't really have much gargle to it once the engine is up to operating temp. With the timing amounts changed drastically during the warmup cycle (when most people seem to video for whatever reason) everything is amplified.
We also have a turn down system for that truck, however it's pretty loud both inside and out. It's just a small catback system with a turn down prior to the axle.
#39
perfect. i can deal with that. and rohr, you never get much drone right? i do remember seeing how you adjusted to get the tip to be out from underneath the bed, and that stopped some droning, so i know to try that.
not seeing many reasons to go with the maggie catback or why its so much more expensive.
and im sure i want a siso system.
should i spend the coin on the t304 system? or just go with 409?
#40
Do you like your exhaust shiny or do you not mind the brown surface rust? 409 will develop surface rust (but wont rust holes through like aluminized) but t304 stainless will remain nice and beautiful. Another reason I like Borla and Corsa, aircraft grade t304 stainless.
#41
#43
narrowed it down to three kits
Magnaflow SI/SO
MBRP SI/SO
MBRP SI/DO
im finding the videos are mixed, especially with the mbrp stuff. all im after is no drone and no cackling, or gargling effect. some of the videos of mbrp stuff do it terribly, and some dont do it at all.
for instance jesserohrs thread when he put his mbrp siso kit on his 08, sounds perfect, first post in this link
https://www.f150online.com/forums/20...-photos-3.html
but when on youtube you find ones like this
http://www.youtube.com/watch?v=T0d8e1wXSp0
notice its popping when it revs down
then the dual kits sound like this:
http://www.youtube.com/watch?v=36KwIq1WjVU
(which doesn't make the popping noise)
then this one
http://www.youtube.com/watch?v=ILkOJKgVJfE
which does do it.
from my mustang experience, the popping cackaling sound comes from not having cats. but all of these trucks seem to be newer, so they should have those 2 big cats instead of the smaller ones. maybe there gutting their cats out.
svets does your mbrp sido kit do this? did you leave your cats alone? are yours the side exit?
Magnaflow SI/SO
MBRP SI/SO
MBRP SI/DO
then this one
which does do it.
#44
