Where to get a leveling kit in canada??
Heres the link to their stuff for Ford
Ive order quite a bit from these guys. I put a lift for my Ranger from these guys through hell and back and held up very well.
2.75 is starting to push it on the leveling kit size.
if it was my truck i'd go with a 2.5" leveling kit (if you can find it) and nothing for the rear unless you want to keep rake. the 04-05 have more rake from the factory due to different leaf packs in the rear so it takes more to level. if you want some rake and don't tow i'd use a larger block (better ride than an AAL), if you do tow either go with an AAl or airbags (you can adjust your height slightly with these which is a plus IMO)
