4WD Noise Drivers Side
Hi All,
I have had this strange noise coming from the front of my truck, and I did some research on here to find out possible ideas of what it could be. After changing pulleys and the tensioner I found out here that I should look at the IWE. Well reading about the system people, suggested try changing the solenoide first then if problem still exists then check the vacuum lines, after that check the IWE or HUB. Well, I have replaced all of those and now the sound has come back clearly on the drivers side still. It no longer make the noise on loaded conditions as in trailering, hills etc. , but now it does it at high speeds all the way to a complete stop, but still randomly. Please help with any suggestions or ideas as to what else I can check.
Hi All,
