Pity Party Invitation (Hit and Run)
what i can see from your pic:
1) lower control arm
2) cv axle
3) possible strut depending on if the axle hit it hard enough to bend the shaft
4) there appears to be some broken metal on the ground directly under the diff that you can see through the control arm. possible diff housing damage??
5) the portion of the frame where the rear of the control arm bolts to appears to be bent/torn along a weld seam.
6) sway bar link is bent
and this is only what can be seen on this side. possible damage passed through these items to the other side of the vehicle must be considered with a hit like this. i hate to rain on you but damage like this which is clearly visible on a 2005 will be expensive to an insurance company. in other words they might be totalling it out.
2) cv axle
I just put new brakes and rotors on last Wednesday. I wonder if those were affected at all!
Not all dealers have body shops, and the ones that do are varying quality. I would ask around with people you trust to get a recommendation for a GOOD local shop.
Several years ago, I got a contract to install wi-fi in body shops so they could update the computerized frame racks online. I partially judge a body shop's quality by how clean it is. The absolute WORST shop I was in was at a Chevy dealer. The bondo dust was so thick I could barely breathe. One shop I went to was so clean you could almost eat off the floor. When I needed some work done on my truck a few years later, I went to that shop and I am completely satisfied with their work - they did a job that you can't tell was even done.
I'm concerned about where to take it?? Should I take to my dealer, or a body shop? I believe in my state, since I am not the insured... I can take it anywhere I prefer. I do not have to go where the insurance company wants me to.
I hope they don't total it!!!! I purchased this truck brand new and have completed all of the scheduled service. As well as all of my modifications!! They will never be able to reimburse me enough to get another comparable truck!!!!
I normally do... but I was doing yard work and didn't move my truck back to the driveway when I was done! I also put in a basketball hoop which has me parking no the street far more often than I did the first 5 years I had the truck.
sorry to see this. The fact that they'll only cover $7500 kind of stinks.
I have a question about this pic. Was the inner axle flange assembly ripped out of the differential? Wouldn't that mean something in the case also got fubared?? Are the pieces of metal on the ground part of the case??
