cant get wheel off
These wheels are hub-centric, which means that they center on the hub and not the lugs. That being said what you have is rust holding it on.
Put the lugs back on and leave them with about 1/8" gap to the wheel, lower the truck back down to the ground and shake the crap out of it by rocking it side to side. That should pop it loose for you. Then raise it back up and go about it normal. Once the wheel is off clean the rust/crap from the center of the wheel and the hub.
Should be good to go. Good luck.
As was said before, loosen the lug nuts a couple of turns then give it a good jolt. I'm a little more old school, however. I lay on the ground on my back and give a good hard kick with both feet to to top of the tire, right with the rim and tire meet. More energy than a hammer and, if you've made sure there's no rocks cought in your shoe soles, less chance of marring the finish on your wheels.
Do this with the other three wheel on the ground, the parking brake set hard, and a sturdy jackstand in a solid location under the wheel (which should only be off the ground just enough to let it spin freely).
By the way, works better and is easier on your feet if you're wearing a set of heavy sole work boots.
Brad
Brad
