Running 2 Highflow Cats on my 5.4 F150, Any Issues? Engine Light?
You have near 85k miles correct? ( judging from your spark plug swap thread to current day ), maybe buy some new O2 sensors. Some sensors fail out after a cat swap if they are aged enough. It doesn't take much dust to make them taint the sensor either.
If you have the funds for rear sensors, its worth a try.
Thanks went out and looked at the cats setup....just want to make sure you all have the same setup as me.
02s - first set of cats - 02s - second set of cats.
Any idea why the 2nd set 02s are before the 2nd set of cats? Are those cats not serving any purpose in cleaning the exhaust? In that case, putting the 02s in the high flow cats and deleting the front two should make it not throw a cel....just my thought.
Picture thumbnails:
Picture thumbnails:
I originally had planned to remove all 4 and just replace with 2 high flow cats and plug the rear 02s in but now I'm curious about trying to cut out the rear two and putting the highflow with the rear 02s in it and see what sound it makes...if its not loud enough I'll cut off the front two.
I currently have Dual Magnaflow Mufflers with an X Pipe that make it decently loud, just tired of my damn rattling cats lol (hoping it's the rear cats that are bad).
