advise on 07-08 f150s
hey guys i just sold my 2004 fx4 and im looking to buy an 07 or 08 f150 fx4 5.4L. im just wondering if there are any common problems with the 07's and 08's like the cam phazer noise that the 04's and 05's had, its drove me nuts big or little problems the more info i can get the better, i want to be confident when i buy
I have looked here before, searched, etc ..... what is defined as "Late 2007" (meaning model year I guess)?
I doubt you'll need the Lisle tool. I had the same thing (an 08 F150 with black boots) and changed my plugs at 65K miles. No breaks, and the plugs looked just fine after following the removal procedure of letting them soak in penetrant oil (I used PB Blaster). Plugs still had plenty of life in them. The only thing I'd recommend is that you make sure to put some Nickel anti-sieze on the extrode shank for good measure. I don't intend on removing mine until it hits 150K or so.
Thanks for the direct and up beat and speedy reply!
Might push that back to 70-80K?
Later ......
