2006 4.6 motor dies at idle,restarts easy
My 2006 f150 with the 4.6 and a K?N air filter, dies at the stop light, it restarts w/o problem runs a bit and will die again at idle. Driving seems to clear it up, but when you roll to a stop and idle situation it will die. 57000 mile oil change every 3000. any thoughts?
my 4.6 used to do the exact same thing. i pulled the throttle body off and noticed it had some junk built up inside it so while i had it off to clean it, i took some sand paper and went over the connections even though they looked clean. reinstalled everything and never had a problem since..
