Inertia Switch wire question
Fuel Pump Relay ( non serviceable ) -> Dark Green w/ Yellow stripe wire -> Fuel Inertia switch -> White wire -> Fuel Pump Driver Module.
The Pink w/ black stripe that was from the Fuel inertia switch on the 97-03 ( and 04 Heritage & Lightning ) is now from the Fuel Pump Driver Module to the fuel pump.
- Guess it was a circuit color that is to be directly attached to the fuel pump, and the inclusion of the FPDM made it a shorter circuit - Big SWAG on my part as to why.
Not too sure if you want to install the boost a pump on the white wire, you would be increasing the voltage to the FPDM.
You might want to check with the manufacture of the boost a pump, to see if it is applicable in this configuration and if so, if you should have it between the FPDM and the fuel pump ( or somewhere else ).
Well I read on a few people who have wired it up after the inertia switch so the BAP unit could be in the cab. Since our fpdm is under the bed and I offroad a lot I figured that wasn't a good place for me to have wire connections, just sounds like trouble. Lol
Batn68 is one person off the top of my head who did it this way. But I will still do some more reading into to make sure, thanks for the heads up!
