F150 solid axle swap conv.
neither. D60's is all you need for a SAS. Will be overkill until you are running over a 40" tire and abusing the 4wd.
For price, if you can do the work plan on a minimum of $5k assuming you get kick *** deals. i'd guess more in the 7-8k range running leaf springs (i'd go linked and add a couple grand to that price for parts) From your post i'm assuming you can't, and i'd at least double that number.
A member here just spent over $30k SAS his (he used the best parts possible on his, look up username ogterror)
