Coil Packs bad?
Coil Packs bad?
I just put new plugs in my 04 Lariat Screw at 100k miles. About a month before that I started to get a vibration between 35-45 mph until it went into overdrive. After its in overdrive it does great. At a dead stop I can put it to the floor and there is no vibration. But if I drive casual it will vibrate between 35-45 EVERYTIME. I heard it could be a misfire.... My plugs were due so I changed them. Vibration still there. Im thinking coil packs. But which one??? I also have a Edge tuner. It does the vibration with and without it. Any ideas?
Thank you,
Chris in Texas
Thank you,
Chris in Texas
You didn't mention that the Check Engine Light Was on,Find someone/someplace that has a decent Scan Tool & have them look @ OBD 2 Mode 6 Data it should show info for each cylinder & if there are any misfire counts,A good scan tool will do much more than pull codes/data you just have to know the tool & where to look.
I had the same problem over the summer...swore it was the overdrive.
Dealer installed a recorder for a week, and it didn't show anything. They finally found a misfire on cylinder 3 and replaced COP. Truck ran good until a few weeks ago...same problem. I bought one new COP, and am trying to figure it out. My ACTRON scanner doesn't show any codes, and no check engine light.
I started with cylinder 1. No more miss, but truck boggs down after shifting into overdrive...maybe multiple misfires?
Regards!
Regards!
