most brilliant leveling kit idea ive had in a while. diff leveling kit sizes.
so i was thinking today about whether i should step up to a 2 or 2.5 inch leveling kit in the front, and it hit me, just put a jack under the front and measure the fenders and see what each looks like.
this is what the truck currently looks like with a 1.5" autospring and nothing in the rear except for the factory 2 inch block.
so today i put it in my driveway, and measured the ground to fender height. here it is with its 1.5 level. front fender measured 40.25 on this side
then i put the jack and board under it, to the frame rail in front of the front diff, and jacked it up till it measured 40.75 (it was .5 inches higher on both sides of the truck, driver and passenger) and this is what that looks like, so this is essentially a 2 inch leveling kit
then went another half inch, so the fender to ground measured 41.25, and again it was 1 inch higher than stock on both sides, so this in theory is a 2.5 inch level
i know it seems like allot of work because im trying to figure this out. i want the front a little higher, but pictures confuse me. this guy on f150forum says this is a 2.5 and 35s, i pmed him about it and he said at one point it had a taller block, but im still waiting to hear if this pic was with or without that taller block.
then the pic that really confuses me, this is mdhawkins truck everyone, not mine. he has the same color, same year, same tire size (trail grapps, not terra like mine) and he has a 2.5 inch level in the front
see how his doesent look like the fronts higher?
im thinking 2" is the way to go, however, if i went with a 2.5 id rock it for a while, see how i liked it, and if i wanted to bring the back up id make a .5 inch zero rate for the rear, then id be .5 inches taller all the way around. the good about the 2 inch is that i could do rancho quick lifts
what are your opinions
"ply"
Im putting a 2.5 quick lift on tomorrow, then 35's on 20s wed. Ill take some pics so you can see what it looks like.
Not sure why some do and others don't, but a couple months after having my 2.5" leveling kit on, a boot was torn and grease was slung all over the place. I blamed it on the leveling kit, but ran it about another year with no issues before removing it and installing my Rancho.
