Volant CAI & Edge?
Old 03-07-2012 | 01:32 AM
JoeyStags's Avatar
Cool Volant CAI & Edge?
I just purchased a Volant CAI # 197546
I also have a edge programmer with factory tunes, my question is i have been reading on here is alot of people recommend a set of custom tunes on the edge....
Mods-
Volant CAI
Edge Programmer w/ factory tunes
Roush Dual Off-Road Exhaust Kit
Just wondering what everyones 2 cents is and where do you recommend me getting custom tunes done and what is the cost
Thanks,
Joe
Old 03-07-2012 | 08:37 AM
The Edge tunes are written for the stock intake. Running a CAI on a 2004 and 2005, there is a high risk of running lean unless you have a custom tune. The only company allowed to custom tune an Edge is PHP. Go to their web site or call them to check prices.
Old 03-07-2012 | 10:47 AM
MGDfan's Avatar
Old 03-07-2012 | 02:19 PM
mkinttrim's Avatar
I'm at 6100 ft with a volant and edge and I have zero problems at all.
Old 03-07-2012 | 02:38 PM
MGDfan's Avatar
Originally Posted by VMP Tuning
We can tune for different cold air intakes on 05+ Mustangs and 04+ F150s. Any aftermarket intake that flows well and puts the slot-style MAF sensor into a larger less restrictive housing is going to REQUIRE a tune for the vehicle to run properly. Intakes that do not require a tune are often just as restrictive as stock and do not result in large power gains.
Originally Posted by Troyer Performance
Hang on there - no, you CANNOT just put any intake kit on the 2004 & newer F-150's with the 5.4 3-valve motor, as virtually ALL the CAI's on the market for those vehicles WILL in fact cause the engine to go *drastically and dangerously* lean. It's not like the 2-valve & 4-valve modular motors, the 3V's have a different MAS system and it's far more unforgiving of changes made to the air intake tract. What Bartak1 very kindly responded with is accurate info for the 1997-2003 trucks, but not for the 2004 & up 5.4 3V motors.
We've gone over all of this many times before, so you can use the SEARCH feature here to retrieve & read any of our hundreds of previous posts on this exact topic.
By the way - THANK YOU for asking about this before doing it - so many people just accept what the various manufacturers claim and slap on intake kits and then have problems, or in some cases don't get any warning lights on the dash - we've seen 19:1 lean not throw a code on some of the 5.4 3Vs during a full-throttle dyno pull, and that is scary.
And: https://www.f150online.com/forums/3542560-post9.html
More, from Lord Suzook: https://www.f150online.com/forums/3542531-post8.html
Can't tell without a wideband - period.
MGD
Old 03-07-2012 | 02:51 PM
SoonerTruck's Avatar
@MDG, should have found a picture of Putin and the Roulette table, lol.
Old 03-07-2012 | 02:54 PM
MGDfan's Avatar
LMAO !!!
MGD
Old 03-08-2012 | 08:59 AM
DewserB's Avatar
TRUCK OF THE YEAR 2013
He dood it!
Old 03-08-2012 | 09:25 AM
In Soviet Russia, truck drive YOU!.
Old 03-08-2012 | 12:00 PM
MGDfan's Avatar
Da, Tavarich!
Nasdrovia!
приветствия
MGD(former KGB truck detailer)
Old 03-15-2012 | 08:30 PM
JoeyStags's Avatar
I installed the volant CAI on my truck and had my neighbor take it to work and he ran a scan on it and said the truck is running fine and IT'S NOT running lean....
Old 03-15-2012 | 10:04 PM
Lol, ran a scan on it. Unless he ran it on a wideband o2 scanner on a dyno, he didn't do you much good.
Old 03-16-2012 | 08:57 AM
If it was a scanner to check for codes, that does nothing to check for a lean condition. You obviously want to ignore the warnings or don't believe we know what we are talking about. Thats fine, it is possible that yours will not be running lean. On the otherhand, you could be dealing it a slow, silent early death. A CAI does so little for performance, no way I would risk it without a tune written for it. Tuners don't cost that much and deliver far more performance than a CAI possibly can.
Old 03-16-2012 | 09:08 AM
MGDfan's Avatar
I don't think yer neighbour really likes you at all ...
Here - show him this and say 'Hi' to him for me - then put him on the phone - I wanna talk to him
http://lmgtfy.com/?q=clueless
So - I posted all those links for nothing? Unbelievable ...
Small changes in the way the mass air sensor and tubing around it is aligned may result in major changes in how the mass air sensor measures the air entering the engine. On Fords, the mass air sensor is used to determine fueling, its also used to determine load. Spark timing is calculated based on load. If your mass air transfer function is shifted lean, your car will be too lean and it will have too much timing, which is a very bad combination.
Definition of Load and the MAF's involvement: LOAD_ABSOLUTE = [air mass (g / intake stroke)] / [1.184 (g / intake stroke) * cylinder displacement in litres]
Yer totally on yer own now buckwheat, you obviously don't really care about yer truck enough, so WHY SHOULD WE?
Enjoy yer Bromance with yer neighbour
Old 03-16-2012 | 09:17 AM
DewserB's Avatar
Quick Reply: Volant CAI & Edge?
