20" to 18" Wheels/Rims
Yes, if you don't want to have to recalibrate the speedo, get an 18" wheel with tires the same diameter as your 20s. I think the stock size on the OEM 20s is 275 55 20
Tire size Calculator
NOOO! You will have to get an 18" tire, but if it is not the same height as your 20" tire, your speedometer will be off unless the PCM is recalibrated. It will be a completely different size to be the same height. There is a sticky at the top of the tire and Wheel forum where you can compare heights of tires.
A 275/65/18 , 265/65/18 or 255/70/18 will get you very close to the same tire diameter as your current 20s
Yeah - I'd be looking for something similar in Diameter to a 20" wheel stock. I currently have 275/55/20 on 20" rims and am thinking about switching to 18" rims. I want a tire size that would be equivalent to the 20" tire so that I do not have to recalibrate my speedometer - by the way, is recalibrating the speedometer a big deal? Hard to do?
