Truck will not idle
Truck will not idle
Need some help here. I'm having a problem with my 05 fx4 idling once warmed up. The truck runs great on the hwy and also on the short trip to the store.
The odd thing is this started the day after I changed my oil. I did put synthetic oil in this time. Would this have caused a problem?
The truck has 165 K on it. I changed the plugs and fuel filter about two months ago and the truck has been running great up until the oil change. The oil level looks fine.
After driving it for about 20 min the idle issue will start when in traffic or coming to a light. It's also seems more pronounced when going into reverse.
It sounds as if several of the cylinders are cutting out. If you tap the gas it will recover.
