The mysterious noise when towing
On a recent fishing trip to NY from PA I got this noise coming from my rear passenger tire area. I am only towing a tracker pro team 175 bass boat that weighs 2000k at the most. The best way to explain this noise is when you grind a piece of aluminum on a sander. I eliminated the trailer because i hooked it up to my brothers jeep and my dads f150. I hook my truck up and bam, there it is. Its almost very faint when I am not towing anything. I just put new brakes/rotors in the rear, took everything apart put it back together and the noise is still there. What adds to this mystery is that when i hit the brakes the noise goes away. Could it be my axle? Anyone have any input because i am stumped!!!
Starting to narrow down the problem. Its making the noise when i am towing because there is weight in the back end, I can hear the noise even when i am not towing but only when going over potholes. Basically this noise is gengerated when the spring sags or there is weight on the shocks. But why does it go away when i hit the brakes?
I have a 2004 and had a funny rear end noise - kind of a ticking noise that was louder with a rear load. First misdiagnosed as rear U joint. Replaced U joint - noise still there. Finally discovered a heat shield over the rear drive shaft that was coming in contact with the drive shaft. Got shield out of way and no more noise.
Took the truck into the dealership to have them look at the noise, they couldnt hear it and they didnt find anything wrong. They said everything looks good. Well now when I can hear what sounds exactly like an airgun when i hit a bump or pothole that is primarily on the right side. Whatever is wrong this is driving me nuts!! Does this noise that sounds like an airgun help with anyone explaining to me what this is?
