2004 5.4 spark plugs
Hey guys,
I've read all the spark plug threads I can find, and want to make sure I use the "best" plugs I can to help avoid future issues.
Here's my story: I bought it new in 2004. Later, I learned of the famous 'spark plugs break upon removal' issue. I had 37K miles on it at the time, and went ahead and changed my plugs then.
I blew out the spark plug holes with compressed air, soaked each one with PB blaster for about half an hour, and carefully went for it. I lucked out and got all eight out without any breaking.
They all came out very, very tight and creaking and groaning the whole way out. I would do a half a turn, spary some PB down there, and reverse direction, turning them back and then reversing them again and bring them out a little further each time.
I was sweating bullets, because at that time the Lisle tool wasn't yet out, and back then the standard for broken plugs was head removal.
Anyways, I now have 124K and have developed a miss under load. P0305 is stored (#5 misfire). I plan on changing all the plugs and the #5 Coil.
I used anti-seize on the heat shields, (but not the electrode bridge) and also a small, thin dab on the threads when I did them at 37K miles.
Do you think they should come out easier this time?
And what is the proper motorcraft plug to use? SP515? I can't remeber what the motorcraft part number was I used before, it's been a few years.
Any suggestions to ensure this goes smooth? I guess having the Lisle tool handy is the best thing I can think of.
Thanks for any advice on this.
SP515 is the current recommendation.
Have a Lisle tool available, and use the crack loose/soak method. The current soak recommendation is carb cleaner.
Something else that helps is to get an intake cleaning (BG or Motorvac) done, or at least run Techron through a couple tanks of gas beforehand to loosen and burn off the carbon.
Don't fear the Champs - done correctly they work just fine.
Don't wait so long between changes!
Use NEW boots.
The Lisle will handle all thre currently seen brekage modes.
MGD
Yes, swivel required. I think. I did mine a few years ago. I think the plug socket I bought was a swivel type. I'd have to go look at it. Maybe not required, don't remember.
If this was a normal engine with normal spark plugs, I would say sure, go for it with a regular 9/16's deep socket.
But with this insane head design, the odds are really stacked against you, trying to remove these things without breaking them off. A spark-plug socket will have that rubber insert inside that supports the porcelain part of the spark-plug.
Here is how i did it with an IMPACT...
- You can use a standard 9/16 deep socket for the plugs. What i did was just take the rubber piece out of an extra 5/8 plug socket i had and cut a slot out of it and it slipped right into the 9/16 socket and worked like a charm.
[youtube]iIQevez-DG0[/youtube]
It doesn't look the guy in the vid used a swivel. I'll test fit every plug to make sure it fits correctly.
That's reassuring to hear.
So you think mine will come out easy this time? They have almost 90K. I used whatever the current motorcraft plug was in 2005, can't remember the PN.
And, I used anti-seize.
youre not supposed to apply anti-seize fyi. i mean you made it this far just fine so no biggy, but the coating on the new 515s is anti-seize. i just did the plugs on my 5.4 and asked the same questions as you, and everyone including my dealer said noooooo anti-seize. and yeah 515 is 1 piece but dealer still recomends every 60k. not to burst your bubble, but my dealer did fuel treatment, intake treatment, and soaked them overnight and 3 still broke. so just be preparred ya know
The barrel/ground shield on the SP515 is still the exact same size as the previous versions. This had been confirmed via direct measurement.
The SP515 is still a 2-piece plug - albeit one that appears to be slightly more 'sound' in the crimp area.
Hi-temp Nckel ( NOT copper) anti-sieze is still specified - IN THE TSB, which has NOT be superseded or retracted - to be applied to the ground shield to minimize seizure @ the next change, no more than 60K hence. You are correct, though - no A/S on the threads is specified.
The root cause and physics of this issue have not gone away, sadly.
Seems the end-users are getting at least (or more) adept at removal without breakage than some of the dealers. Seems the savvy dealers are using an impact on a warm engine with great results - and no protracted soak - in & out in 2 hours or less. Yer dealer appears a bit behind the times....
MGD
