Superlift lift kit any good?
Old 08-30-2012, 04:55 PM
dbhost's Avatar
I am looking at a 4 - 4.5" lift for my truck, and am looking at the Superlift. I never see any of them on the forums, but I know they are out there, as I have actually seen the guys are 4Wheel parts installing them. I just don't know if they are worth a hoot...
Can anyone clue me in here?
My other option is the Rancho, and I can't seem to find them in black anymore, so I would end up having to pay to repaint the suspension components on top of getting the stuff and installing it... (I don't like the bright red free advertising for Rancho under my truck...)
Old 08-31-2012, 05:51 PM
andeez's Avatar
i have the superlift kit. i really like the front design with the skid plate integrated. The rear is only an add a leaf. i was planning on putting 35" from the start. My front tires rubbed allot. I bought the billstein shocks that are adjustable from 4 to 6". i have them set on 6" and i have a 5" lift block plus the add a leaf on the rear. No rubbing. Anything less than a 6" lift
35" tires will rub unless you never plan on turning. Buy the billsteins and the 5" procomp block. $12.00 from 4 wheel parts. Do not use the bump stop brackets from the kit. also buy extended brake lines ~$100.00 from summit for all three. Just swapped the gears for 4.56's . acceleration is allot better. only put ~20 miles on it after the gear swap.
Old 09-03-2012, 11:19 AM
dbhost's Avatar
What rims are you using?
I already have 35s with a 2.5" leveling kit using Pro Comp 17x9 4.75" backspaced rims and only minor plastic trimming to get rid of the rub... I would think a 4.5" lift wouldn't even need trimming unless you are running some extreme rims...
Old 09-03-2012, 08:52 PM
SJP1809's Avatar
When I had my 05 I put the 4.5" Superlift on it, that's been a long time ago but from what I can remember it was a solid kit. Here's some pics for reference.
Old 09-03-2012, 09:32 PM
dbhost's Avatar
SJP1809, those rims look like Pro Comp 1079's in 17x9, not sure about the rubber though.
What size tires and did you have any rubbing?
Old 09-03-2012, 09:45 PM
lakemarykid's Avatar
Absolutely love that truck SJP!
-Curtis-
Old 09-10-2012, 08:52 AM
SJP1809's Avatar
I've been out of town so sorry for the late response but yes you are right they are Pro Comp 1079's but they are 18x9.
The size tires are 35x12.50R18 Toyo M/T and from what I can remember they rubbed just a little bit but nothing crazy at all.
Old 09-12-2012, 12:15 PM
dbhost's Avatar
That's a little disappointing to read... My whole reason to do a full on lift beyond my leveling kit is because I want to get rid of what little rub I do get (far back corner of the fender liner at full crank and the suspension compressed).
I think I have explained this previously, but I am in a funny situation. I just love the look, and function of a 12.5" tire, and these trucks look, well goofy with anything smaller than a 33. I was never happy cosmetically with the 285/70R17s I had. They were a good tire, but just looked like a space saver spare to me... I don't want to do a tall lift because, well I have a short wife, and will catch all sorts of grief if the truck is too tough for her to get into...
Old 09-12-2012, 02:23 PM
06yz250f's Avatar
the superlift 6" is only a 4.5" drop so you won't be able to go higher.
choose a brand that is a full 6" drop. as for rubbing, it's all dependent on wheel choice and tire size and model.
Old 09-12-2012, 08:40 PM
dbhost's Avatar
Back to the short wife issue... I am pretty sure 4.5 wouldn't be a problem, 6" would start the fussing...
Light rubbing with the 4.5" lift and the tires pictured below.
Light rubbing with a 2.5" level and the tires pictured below.
I already have my next set of Trail Diggers on order. I am very happy with these tires aside from stupid user caused wear issues...
I'm wondering if the rub problem is because of the sidewall knobby things...
Old 09-13-2012, 12:08 PM
SJP1809's Avatar
What's the offset and backspacing of your wheels?
Old 09-13-2012, 04:14 PM
dbhost's Avatar
Pro Comp 1089 in 17x9 has a 4.75" backsapcing and 6mm offset.
Pro Comp 1079 (your model rim) only shows available in 17x9, and features a 4.75" backspacing and 6mm offset. (a LOT of the sizes previously offered on both of these rims are GONE now...)
Which is why I was wondering about the side biters on your tires.
Also wondering if my trimming will help prevent that...
Old 09-17-2012, 09:03 PM
andeez's Avatar
Superlift sells a 4.5 and a 6" kit. The 6" kit consist of +2" billsteins and a spacer for the rear over what comes with the 4.5" kit . My wheels are the XD monsters with 4.53" backspacing with 35 x 12.50 x 18 nitto trail grappler mt's. Like i mentioned earlier I installed the +6 billsteins for the front and had them set to the +4" setting. My tires rubbed on the cab allot. After setting everything for a 6" lift my tires will only rub if the suspension is flexed real hard. I dont know what people are doing with leveling kits and 35's but from my expereince it wont work correctly. Like i said go with the 6" setup and you shouldnt have any problems.anything less will rub and you will be dissappointed.
Old 09-17-2012, 09:10 PM
06yz250f's Avatar
Because you are running a wheel with 4 1/2" backspacing and not the stock wheel. The stock wheel keeps the tire in the fender so it prevents rubbing except at full lock.
rim width and tire choice will also affect rubbing as well.
Old 09-17-2012, 10:21 PM
andeez's Avatar
[QUOTE=06yz250f;4897803]Because you are running a wheel with 4 1/2" backspacing and not the stock wheel. The stock wheel keeps the tire in the fender so it prevents rubbing except at full lock.
rim width and tire choice will also affect rubbing as well.[/
At 4.5" backspacing it gives the truck a nice wide stance. Why would anyone put 35x1250 x whatever on stock rims? rubs the body , rubs the frame, i prefer not to rub at all. get the full use out of your upgrades. at 6" of lift , its just enough to crack the seal on most women. You remember what you had to do on the glass bottles of ketchup to get it flowing.
Quick Reply: Superlift lift kit any good?
