What floor jack to get??
This is the one they sell at Costco. It rocks:
http://www.adamsautoadvice.com/2011/...r-from-costco/
I quit buying most craftsman stuff after my bench vice that was craftsman, but made in china, crumbled in my hands.
it's not an easy fix when you break the gasket seal.
Sorry I haven't been on here in a while. Not sure what model number or Harbor Freight catalog number but it's a Pittsburgh 3 ton rapid pump. Goes low enough for my son's sports car and high enough to lift my truck with ease. Works great on my tractor too, just had to swap out a tire this weekend.
What do you guys use when in the road?? I have bought two OEM scissor jacks the past couple years. But they are only good for about two uses on these heavy beasts. I am thinking of buying one of the Harbor Freight rapid pump jacks and fabbing a box under the bed...if there is room on the passenger side. My 5.5' bed is too small to just keep the jack in there rolling around.
Have also thought about those inside the bed tool boxes but they aren't large enough inside for these floor jacks.
I jacked up my truck from the frame right at my back door. My Craftsman 4 ton jack was barely tall enough to get my rear wheel off the ground. 19 13/16" max height. A 3 ton jack is shorter.
Where do you jack up your truck at? I almost wish I had a 5 ton jack.
I just replaced my rear brakes on my 4x4 truck that is the highest vehicle off the ground that I have ever owned. I have a question for you 3 ton jack guys...
The 6T stands go plenty high. That's why I purchased them. At times I've incorporated either a 4x4 block or 6x6 block to crank it up that much higher, -adjusting stands as I go.
Right, only if you lack common sense. Yes they were designed to be jacked there with these trucks. There's know design issue about it lol. Do I really have to explain why they say that?
The flat squared surface on the bottom of the differential really tricks young amateurs like myself into thinking it is a temporary usable point. I figured as often as the suspension travels and causes the driveshaft to shake and pull it would be nothing more than that.
