No more crazy rake (new coilover pics)
Upper ball joints were bad. Replaced them with moog. Since I had to remove the coilovers to get the bolts out, I figured I'd replace them too. my truck is 2wd, but I have had oem 4x4 blocks in the back for a long time. That said, the rake was pretty crazy. I went with 4wd coilovers for the front which are just a little longer. It added about 1.5" lift to the front. The rear now sits only 1" higher.
I got a much stiffer shock than oem. While it's not quite as soft, the tightness and lack of body roll feels great.
Also, pictured are my upper control arm angles. Do they seem too steep? Most say I'll be fin.
Pictures taken with wheel off the ground? I had a 2.5 AS spacer on top of mine and looked like that with the wheel on the ground. Only bad thing at full flex the arm would hit the coil. I put around 30 thousand miles on the truck and had no major issues. The angles aren't that bad.
Just hope my ball joins hold up with the angle it put on my UCA. I don't go off road and am really gentle with my truck going overs bumps.
Thanks for the pic. That does look like mine. How many miles have you been running that way? And obviously doesn't seem live you've had any issues.
I've got about 15k with the level and no issues. I don't have many miles on the truck (20k), so probably looking at uca's and rotors down the road to from what I've been reading. I thought about the struts instead of the level, but only had 5k on the original struts so made no sense to do at that time.
