2007 F150 - P0358 code, please help!
2007 F150, 118k miles, 5.4 FX4. Original engine/transmission.
Started to get some shuddering and P0358/P0308 (and other cylinders) codes so I changed the plugs. I did the front 6 (all broke) and I had a shop down the street do the back 2 (both broke). Replaced all plugs with Autolite Platinum HT15 plugs. Ran ok for about 150 miles, but then it started missing again, codes P0351/P0354/P0355/P0358, so I changed the COPs out with Denso COP on Cylinders 1/4/5/8 (front 2 and rear 2). I used plenty of dielectric grease on the boots. Now I still have a P0358 code showing. I just swapped the #8 fuel injector, no go. Still running like crap. I've checked all lines and connections and everything appears tight. Truck runs like complete crap. Is there anything else I should check? I'm going to go re-torque the plugs now, just running out of ideas. Compression test?
to make things worse, after the plug change and 150 miles of running fine, as soon as the codes popped up and truck started running bad my AC immediately stopped working. The compressor isn't turning on. Coincidence? I know the systems are independent, but just seemed odd.
is there a way to see if the ECM is bad, without going to the dealership?
Maybe, I Found This, http://www.ecmtogo.com/ECMTips2.htm Its Tells You All About, How To Check, How To Fix, What It Affects
UPDATE: to anyone that has had this issue, specifically a P035x error, don't replace anything right away, go to the dealership. There is a tech service bulletin out that details the issue, faulty PCM (or ECU or ECM, whatever you want to call it) - see below. This is what was causing the misfires and A/C to shut off. $1,250 later I should have my truck in about 5 days as the PCM ships directly from Ford.
20680 GAS ENGINE COIL ON PLUG(COP) DIAGNOSTIC TESTING
WHEN DIAGNOSING COIL ON PLUG (COP) IGNITION PRIMARY CIRCUIT MALFUNCTION DTC'S P035X-P0360
ALWAYS VERIFY HARNESS INTEGRITY USING PCED PINPOINT TEST JF. IN RARE INSTANCES COIL DTCS CAN
BE A RESULT OF PCM DRIVER FAILURES. TO CONFIRM PCM DRIVER FUNCTION USE IDS TOOLBOX OSCILLOSCOPE
"ESCAPE PCM DRIVER" TEST TO VERIFY PCM FUNCTION. WITH NO VEHICLE SESSION ACTIVE SELECT TOOLBOX
THEN OSCILLOSCOPE FUNCTION. SELECT THE ESCAPE PCM DRIVER TEST. FOLLOW HOOKUP SCREENS FOR
CONNECTING THE CURRENT CLAMP AROUND THE HARNESS AT THE ENGINE POCKET CONNECTOR OF THE PCM.
MISSING COIL DRIVER PULSES FOR NON-STANDARD COP COILS CAN BE IDENTIFIED USING IDS POWER BALANCE.
IF MISSING PULSES ARE OBSERVED FOLLOW PCED DIAGNOSTICS TO RESOLVE. IF ALL COIL PULSES ARE PRESENT
DON'T REPLACE THE PCM. TEST DISPLAY SCREENS ARE AVAILABLE IN THE ESCAPE DRIVER TEST HELP LIBRARY
EFFECTIVE DATE: 02/25/2009
20677 GAS ENGINE MULTIPLE COIL PRIMARY CIRCUIT DIAGNOSTICS
DIAGNOSTIC TROUBLE CODES(DTC) P0350/P035X-P0360 CAN ONLY BE SET BY A PRIMARY CIRCUIT MALFUNCTION.
A SECONDARY IGNITION FAILURE(SECONDARY COIL WINDING OR SPARK PLUG)WILL NOT SET A P0350/P035X-P0360
DTC. IF A P0350/P035X-P0360 DTC HAS BEEN SET, THE PCM WILL INVOKE FMEM (FAILURE MODE EFFECTS
MANAGEMENT)WHICH WILL SHUT DOWN THE INJECTOR FOR THE FAULTED CYLINDER IN ORDER TO PROTECT THE
CATALYST. THIS IS NORMAL OPERATION. DO NOT CONDEMN THE INJECTOR WHEN A P0350/ P035X-P0360 DTC IS
PRESENT. A PRIMARY CIRCUIT MALFUNCTION WILL ALWAYS SET A P0350/P035X-P0360 DTC BEFORE A
P030X(CYLINDER X MISFIRE DETECTED). IF THE CAUSE OF THE PRIMARY CIRCUIT MALFUNCTION IS A SHORT TO
GROUND, THE IGNITION COIL WILL BE DAMAGED WITHIN SECONDS; HOWEVER, THE PCM WILL NOT BE DAMAGED.
DON'T REPLACE THE (PCM) WITHOUT VERIFYING COIL DRIVER FUNCTIONALITY.
