I need some help , truck misses ,dealer at a loss
INFO ADDED: I need some help , truck misses ,dealer at a loss
2007 5.4 F-150 63,000 trouble free miles. Driving the other day engine started missing real bad on acceleration, couldnt get over 45 mph. Pulled over shut it off and restarted and ran better but still missed, engine light would flash when missing then stayed on solid.
Took to dealer they said oxygen sensor was bad and cats plugged. They replaced the cats under their extended warrenty
I picked up truck and it ran alot better until I stomped on it to pass. Whwn trans kicked down it missed bad then stops when it upshifts.
Every now and then it might just hesitate upon normal driving but not bad, never through a code
Took it back to dealer and they couldnt figure it out .
I am greatful they arent randomly replacing parts until they find whats bad but I do want it fixed.
Any ideas guys??
Any ideas guys??
this. run some good quality gas, then if no improvement change the fuel filter, then if no improvement do the plugs. this is just cheap/easy to more expensive. but i would say its plugs
Thank you for the replys ,one more bit of information.
From a dead stop under full acceleration it runs like a top , no hesitation/miss at all. It is only when cruising at speed and stomp accelerator that it misses/hesitates when downshifts then stops missing after it upshifts and continues to accelerate
Could this still be plugs?
Thanks guys
Thanks guys
