Would this injector cleaner do any harm?
I need to try and hunt down a P0171 code system lean bank 1 and I figure the injector might be the issue. I was going to use this injector cleaner but I want to make sure that it won't harm anything else like sensors or what not by using this cleaner.
Any experienced insight is welcome.
Will it hurt the engine?
Absolutely not.
Will it do anything good for the engine?
Absolutely not.
It's 70+% kerosene and the rest is a light oil.
Yer looking for either Stoddard Solvent or a P.E.A, both are the best injection system cleaners available. You can find it in Gumout WITH REGANE, Techron, or BG44. The Regane is going to be cheaper.
Absolutely not.
Absolutely not.
BG44K still shows to be 40% kerosene, 40% Stoddard Solvent, and 20% PEA. Not quite as strong as it once was but still a very strong cleaner. Issue is availability and cost. The last I saw at NAPA was $28.00 for a can. Regane is about 30% PEA, works great and can be had a Walmart for under 5 bucks.
