Spark Plug Change Help
Yes, PULL the plugs. If there was something in the cylinder when you fired it up, it can beat up the plug tip. You also could have damaged a valve. If any of the plugs are damaged, I'd recommend you go rent a borescope before you put new plugs back in.
You DID use high temp nickel antiseize on the ground sleeves of the new plugs but NOT on the electrode strap and NOT on the threads, right?
As for the antiseize, what part is the ground sleeve? Is that the part below the threads? Like what gets stuck in the cylinder that the Lisle tool pulls out? Put it on that? Sorry for all the questions but I really do appreciate all of your guys help. Hopefully I can get this figured out. Thank you.
Yes I did know to use anti seize, in fact u had it in the garage. I missed that step after trying to figure out what part of the plug to put it on. It can get very confusing with so many people saying so many different things. I know 25 ft lbs is right I just think that my father's torque wrench is bad and it didn't actually torque them to 25. He did get it ridiculously cheap at a garage sale.
So I finally got the truck running good. It ended up being two bad spark plugs. Found the missing cylinder by disconecting the coil wire on each plug with the truck running. Found one missing cylinder. Swaped that plug with the plug in cylinder one and the problem moved to that cylinder. Did the same thing on cylinder 8. Put new plugs in both cylinders and all is good. Thank you for all the help, much appreciated.
