HELP.....changing 4x4 vaccum lines
So....I am losing vaccum to my IWE's so I decided to change my check valves and run new lines. So, I took off my air filter box so I could get to the lines that run behind that. As I was pulling off the first check valve, I pulled the red vaccum line from behind the air box. I tried to find out where it came from, but I had no luck. Anyone know how this goes back together??
Here is a picture of the line I pulled out. And it goes behind the air box and down, and I cant get at it!!!
Have you looked at this thread yet? There are some instructions and diagrams. I have never done the vacuum lines but I did do both iwe actuators. Hope this helps!
https://www.f150online.com/forums/sh...d.php?t=371618
Well I took my truck to ford. 8 mins and $62 later, the guy told me he couldnt get his hands back there to get the line back on, so I need to pull off the intake to get at it. He said they would charge $750 to do the job, but im going to do it myself.
I think if I take off the fuel injectors/rail I should be able to get at it and push it back on. Hopefully this solves my 4x4 from grinding under engine load. I have replaced everything on the system (new lines, check valves, vacuum box, solenoid, IWE's), so this is my last resort
