MPG with Airaid MIT
I drive like an old man. Wait.... I AM an old man! Not looking for a racer, looking for reliability and MPG. I have read posts on other sites that seem to support my findings. They all seem to say that it starts out worse, and eventually beats the stock intake for MPG, once the PCM learns the new air flow.
I will fill up again in a few days, and posts the MPGs.
Thanks for the input.
^^^ See, thet thar's th' thang - thur ain't nuffin fer th' ol' 'puter ta cipher.
But - if it be a'wurkin' fer yall, ah's raht heppy fer ye
MGD
I think maybe it's no longer made, though a few can be found still. True Flow #20502
I'm going to give you my opinion on so-called "CAI's" from another aspect.
1. Unless the airbox is sealed with an external inlet, it's actually a WARM air intake. This will actually cause a LOSS in power.
2. The frequently used oiled filter elements do NOT filter as well as a dry paper or nano filter, and also can foul the MAF.
3. Especially on 04+ engines, the MAF relocation can cause you to run excessively lean.
So - for my money (or lack of), the Gotts with an Amsoil filter is the way to go in my opinion. It's cheap, it works, but it just doesn't look or sound cool.
Thanks, I think so too. It included a red foam filter element (but I use a stock type paper element usually) and a new end that's larger that goes into fender inner. The round tube is a heavy wall aluminum and bracket with rubber bushing where it attaches to same location as stocker did. I was just glad the previous owner installed it along with LoProQT cover and cat back exhaust!
They be outta bidness.
And - they were the ONLY CAI/WAI manufacturer that stated on their website - with graphical evidence ( they flow-tested several units including their own ) - that none of them gained any power.
Their honesty was refreshing after all the Marketing BS bombardment from elsewhere.
Too bad they are history.
MGD
They based their product on providing excellent filtration - and looks.
Yep.
MGD
MGD
I never did any times runs but I always figured if there was free HP hidden in a intake tube, FoMoCo would have found it .... I just like the looks and in comparison, noise isn't much more.
