08 4.6 engine stand bolts
Hey everyone. I just bought an 08 f150 quad cab with a 4.6 4X4 with a blown motor. I bought the new motor and doing the swap this weekend. (changing starter, water pump, valve cover gaskets, intake manifold gaskets, alternator....auto zone).
I tried searching the forum and could not find the bolts that would best work for mounting the engine in an engine stand. I know everyone is saying to use the transmission bolts for the lower end, but what are the dimensions? I ask as I would like to go to the hardware store and purchase longer ones.
Also, since the engine stand has the 4 adjustable L arms, what do you recommend the 2 on the top and 2 on the bottom point to?
Ken
Ken
Ken
Ken
The following users liked this post:
Thanks. I grabbed a bunch of different bolts from the hardware store and found the ones to fit the transmission threads to be a 10mm 1.5 pitch bolt. I'll measure it tonight as soon as we finish the engine on the stand.
Also, on the head of the bolts is printed: 01VK 10.9
