No word on 6.2L
#46
Originally Posted by GerRod
4.6L/248-hp/294-lb-ft OHV 16-valve V-8; 4.6L/290-hp/ 317-lb-ft SOHC 24-valve V-8; 5.4L/ 310-hp/365-lb-ft SOHC 24-valve V-8
#47
Originally Posted by 4xford1
Well let me say that i'm 43 years old and I have no problem with ''***** length''!! I just want HP plan and simple!! Now if your truck does everthing you want then good for you, but there are ALOT of people that want more HP so get over it!!
#48
#49
Originally Posted by guitarman502
ok.... first off.... if you really care about "HP" then buy a different vehicle.... second.. compare the f150 towing capabilities to the toyota the chevy with their "376 HP" WOW! not. I'm sorry, i didn't buy my truck to race... if iwould have i would have bought a lightning, or better yet... a car :-0. Everyone was so skeptic of the 04's when they came out and look... STILL the best selling truck in America? How many members do we have on this forum that have f150's? I'm sorry... i had to rant.. i just think its so funny that everyone complains about how "under powered" our trucks are and still yet hundreds of thousands of people go out everyday and tow 8000 lbs. + with their f150s.
No I dont need a different vehicle I need ford to get off there a$$ and build a f-150 that has atleast the same HP as the other trucks out there! Oh and buy the way it's 380 and 381 HP for the dodge and toyota get your facts stright. And yes WOW!!! it is a big deal to some people. I didn't buy my truck to race either but it sure would be nice to be able to keep a dodge or toyota in site if I was to want to race them. And I know ALOT of people that drive GMs, toyotas, dodges that go out and tow that much EVERYDAY and can still haul a$$ after the day is over!
#50
Originally Posted by ThumperMX113
Nope, but it does sound like you could use a bit more intelligence. I can barely read your posts the grammar is so bad. Go back to school and than buy a truck.
If you cant read my post and understand it well your the one with the problem. And I didn't know this was english class.........
#51
I didn't buy my truck to race either, but when I am towing my 8,500lbs trailer, I like to be able to merge into traffic with a little more gussto. If you don't want to be abel to do that, fine you should be happy now.
Fords tow rating is only tops with a Reg cab HD version. On a Screw with 18/20" wheels its only what 8,800. GM is 10,500 and Toyota not sure over 10 anyway....
#52
Some people on here think they know there a$$ from a hole in the ground....But they don't
#57
Where? Please spell it out for us dumb azz'z out here? Post that line in the press release....
Here is a Quote from Det news today: "customers can choose from the 4.6-liter and 5.4-liter V-8s. A diesel engine and Ford's EcoBoost direct injection turbocharged V-6 will be available in 2010. "
Hmmm, sure no 6.2L in that line? What scares us is that its just like Ford (of the last 20 years) to come out with oh lets say 315-325 hp and then say thats good enough.
i made the presumption that the ecoboost options, available in 2010, would include a more powerful engine (the 6.2L being the likely big engine option) since everything else has played out pretty much according to what the more knowledgeable guys (derek,et al) have insinuated so far, and automakers rarely step backwards in the power department with a new engine lineup
i don't apologize for this though: there is a lot of whining over an unknown here--even with the info 'from the horse's mouth' that new engines are coming in 2010...i realize i don't have to read the whiner threads, but give us a break--you have real-world options, exercise them...
all this being said, it wouldn't surprise me if the 6.2L isn't an option in 2010, as ford seems to be taking a proactive approach to engine design with smaller displacement engines making more power per volume...
#59
Man, You guys are THICK!!! Let me take you back a few posts sense you cant keep up...... I said "Some people on here think they know there a$$ from a hole in the ground....But they don't" ....Then ThumperMX113 said ''Sounds like you'' Then I said ''I have forgot more about ford truck than you will ever know.....'' Then you said ''What" Now are you up to date?? Try to keep up......
#60
Here's what Igor had to say about this. He has been correct on a lot of things and Dearborn Derek backed him up at the time this was posted. 2009 1/2 or 2010. Take your pick.
2009 1/2 Model (Februaury 2009) will add:
2V SOHC PFI 6.2l V8 BOSS engine (iron block, aluminium head) with 6speed auto (425hp)
2010 Model (fall 2009) will add:
DOHC 4.4l Common Rail Diesel with CGI block (315hp and 520 lb-ft)
4V DOHC TT DI 3.5l V6 - Twin Turbocharged Direct injected (Twin Force - 350hp, 380 lb-ft at 2000 rpm)
2011 or 2012 model will add:
4V DOHC TT TIVCT DI 6.2l V8 - Twin independent variable cam timing, twin turbocharged, direct injected (Twin Force - over 650 lb - ft)
So in short: The 6.2l V8 will be 6 months late, and the Twin Force 3.5l V6 and the Diesel will be 12 months late.
