Anyone else notice that the 2009 Dodge Ram has coil spring suspension?
Originally Posted by Stealth
Nice find Freeky.
Originally Posted by freekyFX4
Thanks! I was afraid I was going to be chastised for posting this in the 2009 F150 forum, but I wasn't sure where to put it. It looks like a really nice setup. It seems that all of the companies seem to be chasing the proverbial carrot on a stick trying to keep up (catch up) with each other.
Originally Posted by Oxlander
Remember that the original hummer has coil springs on all four corners. I think it will hold up just fine.
The H1 Hummer is an off-road, utilitarian vehicle. It's main job is NOT towing.
What are the Hummer towing specs? Not nearly as good as the F150 (I think they max out around 7k lbs).
Originally Posted by Lumadar
I don't mean to be rude at all, but I don't see the correlation at all
http://www.csihmmwv.com/hmmwv_m998_spec_sheet.pdf
How does it handle heavy loads and towing compared to a traditional leaf spring suspension?
Worse. Remember this is also what a avalanche has. In theory the coil spring is less stabil with a big load. If yoou read the Dodge info they acknowledge this and say they'll let Ford & Toyota fight over the Towing lead... Also why they didn't include a trailer brake controler.... They figure majority don't tow, or if they tow its not typically over 5,000 lbs anyway, so they have more to gain by having the smoothest ride...
So, from a comfort standpoint I really don't think what the f150 already does needs to be improved on (i.e by going to coil springs). Losing tow capacity though is potentially a deal breaker for many people though. Most 1/2 owners don't tow regularly, but there are quite a few of us that need to do it occasionally. Losing that ability would have def. forced us to look elsewhere. Dodge may be in danger of losing future customors because they don't think towing is important.
