Aftermarket Exhaust
Old 02-26-2009 | 01:30 AM
brendanlush's Avatar
Aftermarket Exhaust
Just a quick question. I have an '06 SCAB with a banks monster exhaust. I was wondering if I would still be able to use the exhaust from an '06 to an '09 or would I need to get a new exhaust?
Thanks!
Old 02-26-2009 | 07:46 PM
MyDawg007's Avatar
Thanks!
I called a local Ford dealer that installs a lot of Banks exhausts and they said no.
Old 02-26-2009 | 09:34 PM
Toolcrib's Avatar
If you are going to keep your side exit the same,there is no reason an exhaust shop can't cut you factory exhaust out,and weld your Banks back in. They might have to put a bit of pipe in for length.It is still a way cheaper option than buying the whole system again.
Old 05-08-2009 | 02:12 AM
I am thinking about getting a Platinum screw with the 5.5 foot box. I have an '06 Scab with a 6 foot box. the exhaust should just slip in, i can probably do the welding myself! Are the bends still the same? Thanks!
