Climate control auto button
honestly jack4x4 i think u want to much outta the truck lol ... u want it to AUTOMATICALLY get to the temp u want but u dont want it to turn on?
YES in home that would be expensive but in your truck not so much ... If it worries u that much i think u should just manually set your temperature and fan speed n such
just my thoughts
just my thoughts
Actually my home thermostat is ether set to AC or heat, you need to decide. If you set it to AC and it's already cool it won't blow cold air but it won't turn the heat on either to equal the temp you set. If you set it to heat and its already hotter than the set point it won't turn the AC on. I'm sure there are systems out there that work that way (supply heat or cold base on temp set) but it might get kinda expensive as you cool and heat your house all day trying to make the temp exactly what you set it to. Probably would need to specify a temp range that is acceptable. The tighter the range the more expensive it's gonna be!
Maybe you took me too literally. While my home system (Honeywell) does select weather it needs a/c or heat as needed, yes it has a range of preset temps (and times) that can be as narrow or as wide as you want.
The Ford climate control uses A/C or Heat and blower speed to maintain a specific temp. The Auto feature detects where the air should go. If wanted, you can select defrost and still have the climate control maintain the desired temp.
My 2004 with EATC almost always had the A/C going, no matter how cold it was outside. Virtaully never did it have the A/C button unlit. No idea why it always had the A/C on even when it was frigid winter outside, but it did.
Haven't had my 2009 long anough to notice a trend yet, but did notice one day the A/C button was off and the next day the A/C button was lit.
All he more reason why I like having simple control and a definite indicator of what is taking place on my 3 ***** (manual AC). Kind of funny but to me I see auto AC as a hassle and am glad I do not have it. I wish you guys the best of luck getting everything the way you want on those sweet new trucks.
I guess I thought that if you push the auto button when it is on, then it will turn off the auto mode.....like all the other buttons work. Instead when I push the auto button when it is on, then the light on the AC button lights up (if the AC was off) even if I have the temp set to 80 deg. and it's already less than 70 deg. in the car.
For vehicles with auto climate control, just because the a/c lamp is on does not mean the compressor is on, just that it may turn on or be cycled based on what the computers think are necessary.
Don't think to hard. That's what the computers are for. Like jac4x4 quoted from the manual, the computer decides it all and controls where the air flows, how much to move, and if the ac compressor should be on. If you don't want it to control any of that, don't use auto mode and pick it yourself. Well, except you still cannot disable a/c in the modes I listed above.
I ran my 07 in Auto, and run my 09 in Auto. What I have noticed is, there is a certain outside temp that determines whether the AC button lights up or not. Not sure what the temp cutoff is, but I would guesstimate that when the outside temp is above 60, the AC light will always come on. When it is below 60, it does not come on. I have never had it light up when it was below approx. that temperature. I usually just turn the AC back off if I don't want it on.
