Climate control auto button
Old 04-03-2009 | 03:28 PM
HotLap's Avatar
Originally Posted by 3kgtSL91
well even with A/C on it doesn't mean that it will blow cold air, A/C also makes air dryer in the car and that I believe is why it kicks on... correct me if I am wrong but just my .02
You are correct, the AC generally runs whenever the climate control is in the "Auto" position....it "conditions" the air - not just cools it. Basically, it greatly reduces the humidity in the air (more comfort and keeps the window from fogging) and will run even if the temp is cold and only heat is needed. This is the way it works in all my vehicles.
  #32
Old 04-03-2009 | 04:26 PM
jac4x4's Avatar
Originally Posted by CometFlash
What was it, jac? How'd you go about fixing it?
Not sure of the exact cause but I found a fix. I just placed a small plastic shim between the plastic door panel and the metal door frame. Seems like there is actually something that is loose inside the door panel (wiring?)and by shimming it a little makes whatever is loose in there not bump up against it anymore.
Kinda sucks having to do this cheesy stuff to a new truck but it worked and I don't want to remove the whole door panel to find out exact what is going on cuz I'll probably mess something else up.
  #33
Old 04-09-2009 | 12:00 PM
BIG_ole_TRUCK's Avatar
I don't know what the fuss is all about. The auto climate control system is just that - automatic. Dial the temperature you would like and leave it to the system to think of how to heat or cool the cabin air to meet your desire. If it runs the A/C system, so be it.
