Tundra CrewMax or F-150??
#91
The frame is flexible, but not weak. It's an engineering thing. Flexibility allows stresses to be spread and absorbed - instead of breaking things. This flexibility allows objects to be built considerably stronger for lighter weight. Think bridges and tall buildings. They are built to flex also. Incidentally, I believe the Super Duty Ford trucks are of the same design. So if you think the c-channel design on the Tundra is weak, do you consider the c-channel design on the Ford Super Duty trucks weak also?
Here's a quote from Bruce Arnold, the chassis systems engineering supervisor for the super duty program.
"All of the big trucks use an open frame configuration"
"When you go up in capacity it's actually more efficient from a weight and strength perspective to go open-C"
That's why my Tundra will effortlessly, and smoothly, tow over 10k. I've done it. And the truck handles it very well.
Flexibility doesn't mean weak. Got it? If not, go talk to an engineer and they'll explain why it's so.
First of all, the reason "big trucks" use C-channel frames is because they are much easier to bolt things onto. Do you know what all is bolted onto a semi's frame? Obviously not.
For what a 1/2 ton pickup does, a fully boxed frame is superior. And don't even try to justify your Toyota just because the Super Duty also has a C-channel frame. The steel is MUCH thicker than your weak *** Toyota frame.
The bottom line is Toyota comes into the truck market thinking they can win with horsepower, while ignoring everything else, and were shown just how hard it is to make a dependable truck.
#92
#93
Okay, okay your both kinda right ( I know that statement is going to get some spaming) and your both kinda wrong (that one will too).
Semi's use open C-channel for one key reason, flexability. If you combine 500+hp, 1000+ ft/lbs of torque and 80,000lbs with a fully-boxed frame all that rigidity is going to cause something to crack. C-frames allow all that torque and twist to be absorbed along the entire frame and so it bends and it doesn't break. But bear in mind a Semi C-channel is HUGE, 14-16" if memory serves me correctly. Now as far as the F150, since there is nowhere near the kinda of abuse, power, and weight being combined the boxed frame is superior because of the strength it emparts to the truck. Like MOFord said for what a 1/2-ton does the boxed frame is better. As far as the superduty is concerned the abuse and added torque of a diesel engine lends itself to a c-channel frame, but it is thicker than the Toyota.
#94
#95
Hey. Funny how this came out today:
http://www.thebostonchannel.com/inve...50/detail.html
What do you think?
What do you think?
#96
http://www.truckblog.com/story-5537-...frame_problems
What do you think?
What do you think?
#97
#98
The source has even worse pics:
#99
I certainly don't. I try to stay within Toyota's recommended max specs. I don't know what those are for the 09 F-150. That's why I asked. I still don't know the actual numbers as they come from Ford. Dunesgirl mentions it can legally tow as much or more than the Tundra, but I was looking for the numbers. Guess I'll shop the Ford website and see if they are available.
Nice post, btw, Dunesgirl. I agree with a lot of what you say about the HP of engines in the past. They got the job done - and still will. But, I'd love to read what you'd say about HP if the Ford had the stronger engine.
Of course, one can never be sure what the actual payload is of any one truck without looking on the door sticker for load rating information. So I'm fairly positive if one could get a Crewmax Limited 4x4 5.7L with every available option, that it would have a low payload rating just like the example of the Platinum above. You definitely have to be careful what options you choose to put on your truck, because everything is deducted out of your GVWR to come up with your payload. On a side note, I wonder what the new Ram 1500's payload is like at top level trim with every possible option. Can't be good...
As far as what I would say if Ford had the higher horsepower engine. Well, I will be in the market for a new truck in the next year or so. I've been looking at both the F150 and the Tundra, and was considering the 2008 Ram if I decide I want to buy used. But I like the unique features available on the F150 and that's what I'm going to buy when I'm ready. Ford has a slew of new engines coming out soon, although no real concrete information as to what power outputs will be on them. There's the 6.2L Boss, then a new 5.0L V8, as well as a 3.5L twin-turbo Ecoboost V6. So far, most news seem to indicate that they will all be around the 400HP and 400TQ marks, which makes no sense. Also, it's been said that the 5.0L will be the base engine, with the Ecoboost V6 being a $700 upgrade. Depending on what payload ratings are going to be with the new Ecoboost V6, that will probably be the engine I go with. I'll miss out on the iconic V8 rumble, but if the truck will get 23MPG highway with it and provide a good torque curve for towing, that would be the engine I get. Bottom line, I'm concerned with having good tow ratings, yes. Having the fastest pickup? No, not really. The F150 with the 5.4L with a 3.73 ratio is holding its own with regards to payload ratings against the Tundra 5.7L with a 4.30 ratio.
By the way, I'd be towing an 18-22 ft enclosed trailer with three atvs and camping gear.
#101
Superior? I doubt that's a criteria for automotive design these days - at Ford or Toyota. What probably matters is will it do the job, at cost that will work, at lighter-weight, and won't hopefully come back and bite us on the ***.
I don't care which is superior. All that matters to me is that the Tundra design works for me. So far so good. Having said that, if Toyota comes out with a newer Tundra with a less flexible frame, I'll probably upgrade.
You don't know the Tundra very well. And I'm sure Toyota had a pretty good idea of what they were, and are, up against before they ever started.
#102
Who cares??? The Tundra has a more poweful engine. It's more important to have a quicker 0-60 that it is to have a quality built truck that dont rust away before the engine gets to 100k miles. You guys dont know what your talking about. Crappy Fords with their Realiable, Well built trucks. Ford must think we use these for working in or something.
Well as far as the who cares part...it turns out a lot of Ford owners, being that a lot are buying programmers, cai, etc so they will not get their asses handed to them of the line from the tundra and dodge(also found in the I want more hp threads). But of course everyone buys that stuff just for cruising around town
Back to the original question though, I have rode in all of the new 09's and I thought the Toyota rode pretty good, real crisp, nice ride, but I can't stand how they look from the outside. The Ford rode great, didn't really care for the new 6 speed tranny(I know it would probably get better and grow on me over time)but I just dont like the exterior look of them now. So with that being said I will stick with my 06 and run it into the ground untill a better looking model comes out.
But also don't get me wrong I love my Ford, but I just dont get on the bandwagon to bash other brands.
#103
More flexible to make it stronger?
Someone said earlier that the frame was more flexible to make it stronger like bridges ? Um. Wrong. If you were taking a Naval nuclear power test I would give you a "GCE" Gross conceptual error.
A metals strength, hardness, ductility, brittleness, and toughness are NOT the same thing. Each one is different.
To say a frame is more flexible (or ductile) adds strengh is very incorrect.
When a metal is stronger and harder, it is MORE brittle, LESS Ductile (less able to flex), and LESS tough (lower fracture toughness).
3/4 and 1 ton trucks as well as all or most 18 wheelers use open chanel frames. They have a higher gross weight and can use THICKER metal in the C frame. A 1/2 ton truck should use fully boxed to allow the use of thinnger metal and therefore lighter. There is a happy balance between ridgidity, weight, and cost.
#104
It's amazing how many Gryphon and Edge programmers are being purchased. I don't believe for a second that the majority of the people buying them is just for a better towing setup either.
I know I bought my Gryphon because I wanted to wake up my engine; that and being beat by a stock Civic because his limiter was greater than mine.
#105
Very good point!
To me, this is not contest F150 all the way. First of all, theres the buy american thing. Support your local economy, not that of a foreign country.
Second, the interior on these new Tundra's are junk. Almost to the point where we are starting to tell customers to go someplace else if they want new door speakers because the panels are so flimsy and its not worth the possibility of a damage claim.
Keep in mind that Toyota's quality reputation is for their cars. Their trucks have had numerous quality issues...especially with the frame rotting out. Hell, the frame rails in my 67 Mustang look better then the frames on a 2001 Tundra. I mean, Toyota had to BUY BACK its trucks from its customers on a massive scale. That right there speaks for itself.
