Project sub upgraded
#108
Thanks! Does your amp lose strength or punch on the subs as the volume goes up? If not how did you work out that problem?
Also, how did you get the Scosche FD07B Ford Amplifier Jumper to convert to RCA for the amp or did I miss something? Is the another connector we can use?
#109
#110
#111
Let me know if that dont make any sense.
#113
#114
I am trying to do a similar upgrade but cant figure it out... I am trying to wire in a 4 channel amp and a mono amp from a factory head unit. I don't have the factory sub/amp. My question is How do I get signal to the amps. I have no RCA jack behind the dash (at least that I could see). Do I have to somehow splice the speaker wires in the harness into an RCA cable that I plug into a sound processor and then run another set of RCA's to each amp?
#115
Nevermind I figured it out. However, I cannot figure out what wire harness and reverese I need in order to avoid cutting the factory wires.
I have the XLT (basic radio- no Nav, or sub).
website says FD07B will not work for my truck. Any suggestions? I not keen on cutting the facotry wires.
