keys
the ignition keys that come with the truck I guess. This is my first new truck and as reading about these keys and saw them on ebay. I just wasn't sure if they were all the same kind or not. I read somewhere about how much these keys are when you get them at the dealer and was just curious if they all had that type of ignition key.
I'm pretty sure all models come with the little chip that has to be in the truck for it to turn on, in fact I think its law. However, not all models come with a remote to unlock and lock. None of the trucks come with the fusion key, where the remote and key are the same unit. Hopefully this makes sense.
With any key that uses the transponder (or chip), it's always to go get a spare key so that you have three keys and fobs. If you loose one key/fob, you can still get another and program it yourself. If you have the normal 2 that you get when you buy the truck and loose one, you will dig really deep in the wallet to get a key replaced. It's worth the $30 or so bucks now versus a hundred or more later. Hopefully no one will loose one, but Murphy will get someone!
I got a Fusion key from eBay that eliminates having to carry the fob and it works just fine.
I did the "fusion" key mod on my 07. It is simply a ford key with the remore and key in one unit instead of two seperate(Key and Fob). It is called the Fusion key because the ford fusion was the first vehicle in the ford line-up to use this key (followed by edge i believe).
The truck will recognize up to 4 keys (more remotes). To program it you must have TWO working keys/remotes. and consists of multiple key turns and lock/unlocks.
Find the key, get it cut, program (EASY), then hide your orignal keys from wives/family so they cant steal the truck from you because they are so envious
