WooHoo!!! Finally...
#31
It appears all body styles have a 7200 lb. GVWR. They deduct body weight and options from the 7200 number. So if you have a loaded supercrew 4x4 weight with passengers is much lower.
Thanks for looking at this.
Enjoy that new ride !!!
#32
mg5ford, not a problem at all.
So I was outside changing the orange signal lights. Below are some before/after shots. And I noticed some really poor workmanship on the wire harnesses. I used to work for a wire harness manufacturer as a project engineer and these are pretty bad. I don't know anything about working quality and/or durability yet; but they just look bad. Here are a couple quick pictures. I found the sticker that says the harnesses are made in nicaragua, that explains it.
