Tires
Old 05-06-2009 | 07:04 PM
L8 APEX's Avatar
Tires
I was looking at tires to find a E rated 10 ply tire for 20" wheels. I see the factory size is 275/55/20 which shows to be 31.8" tall in a Nitto A/T. Nitto rates it as an XL load 2833lbs@35psi. The only E is 275/65/20 but that is the tire I have on my F250 and is 34 inches tall. Anyone find a higher pressure rated stock size? It looks like there are more E rated choices in 18" 275/65/18 32x11"
Old 05-06-2009 | 07:17 PM
Power Kid's Avatar
Toyo makes a 10 ply open country A/T I think it's 285/55R20 and while I don't have specs in front of me, I figured out diff in height and it was only like 1.5% so thats what I'll be putting on. And I LOVE that tire regardless, have 'em now. And rim width was ok too.
Old 05-06-2009 | 11:42 PM
SteveVFX4's Avatar
BFG also makes the A/T KO tire in LT-rated 285/55/20, not sure all of the complete specs on them. But I have a set of them and I just bought extra rims from a fellow member and that will be my fall/winter setup.
Old 05-07-2009 | 02:12 AM
Power Kid's Avatar
Suprsied you 'd use them in Winter. Terrible on Ice. But them again I've never neem to PA in the winter...
Old 05-07-2009 | 08:23 AM
APT's Avatar
APT
The 285/55R20 BFG had a D load rating. The Michelin LTX A/T 2 in same size is E.
The XL passenger load rated tires are much lighter and less expensive.
Old 05-07-2009 | 10:30 AM
SteveVFX4's Avatar
we don't really get ice here, just some slushy snow. I never had those tires before, I just got a great deal on craigslist for them. So I thought I would give them a try. I see alot of other truck owners around here with them.
Old 05-07-2009 | 11:00 AM
Tharbold's Avatar
Steve,
I used to run the AT K/Os on my 01 F250 year round. I loved them in the winter - of course I am in eastern PA, not far enough from Philly so maybe we see a lot less ice here - anyway I always thought those tires treated me pretty good in the winter.
Todd
Old 05-07-2009 | 11:06 AM
MarcoPolo1970's Avatar
I am up north in Canada. I ran this winter with Nokian Hakkappalitta's 275/55R20 Extra Load (E) rated. We have everything here: ice, snow, etc... These are the best winter tires I've ever had.
Old 05-07-2009 | 11:07 AM
SteveVFX4's Avatar
^thanks for the feeback Todd!
Old 05-07-2009 | 01:12 PM
APT's Avatar
APT
You can find many-a-post where I state my unfavorable opinion of the BFG AT. it isn't as bad as I make it out to be. I've had better and it sucks buying a worse performing tire than something you've gotten used to.
Old 05-07-2009 | 05:48 PM
L8 APEX's Avatar
The BFG A/T is all about image and name not performance. They wear poorly and quickly.
There was a neat winter tire I read about having walnut shell in the tread for grip...
http://toyotires.com/tire/pattern/ob...ntry-g-02-plus
Old 05-07-2009 | 06:51 PM
BulletMagnet's Avatar
I got 80,000+ miles out of a set of BFG A/T's on an Expedition. I'd say they lasted way past what you should expect for any A/T. I have run BFG AT's on a Regular Cab F-250 V-10, Ranger, and Expedition and never did they wear poorly or quickly. I had Boggers on my F-250 for 9000 miles before they were toast and chunks of rubber were coming out of the side lugs, thats wearing quickly and poorly!
Old 05-07-2009 | 07:16 PM
Power Kid's Avatar
BFGs bite into snow, specially hardpack great, on Ice about as baad as one can find. Not a problem if you don't have ice.
