To K&N or Not!!!!! Your Thoughts!!
I ve used K&N air filters on my last 2 F150's 02 and 06, it seemed to solve the choke point I had with the the 2 trucks when you kicked em in the @#$ getting on the highway etc. I havent noticed the 09 doing this when accelerating to pass or getting on the highway. Is it worth the money for the 09 or just leave it stock? What your opinion?
After looking at some test results I saw on the net some years ago, I would never use a K&N. The test showed the amount of dirt the filter, straight out of the box, allowed to pass through. Much worse with the K&N than with a paper filter.
And that doesn't include problems caused by after cleaning the filter if it is over oiled.
I looked at the air intake system yesterday as I checked the oil level. There's plenty of baffles occupying a lot of space but I suppose it's there for a purpose (making sure laminar air flow occurs into the manifold). The oil saturated air filters are not for my liking. It's too bad Ford doesn't provide performance parts for it's trucks like GM does for Chevy and GMC. Overall, I'm reluctant to change the OEM air intake system at this point.
I use K&N on Carb'd vehicles. No question. They flow more, and with my carb'd motors, I care more about HP/TQ than I do with motor longevity.
on a EFI motor, no way in hell I'd use a K&N. I did once way back when on a 1995 Mustang....up until I found dirt on the motor side of the filter.
The K&N filter just doesn't do a good enough job of filtering. It's just a filter with lots of big holes...too much grit/crap gets through.
And then you have to worry about the oil on the filter messing with the MAF and IAT (if present)
highly recommend a good paper filter
It depends on the operating conditions. Clean city air maybe. Rural or off road, not so much. It gives the dealer ammo to deny power train claims. K&N's have to e oiled to work. Too much oil and it gets on the MAF hot wire element and burns it up. This is real common on GM. GM techs have a bulletin they give every customer with a K&N stating Gm will not warranty any MAF issues. Also more air means more dirt unless you drastically increase the size of the filter. If you trade in every 100k it probably doesn't matter. If you live on a farm and want to go 300k and ten years you will want to stay stock. Donaldson is a good mil spec filter company. I have also used AFE 7 layer stuff on diesels.
