Limp home mode
Limp home mode
So my new 09 went into limp home mode or so ford calls it. The truck was fine then just **** out.. It dint stop running but the speedo just stopped working the wrench light came on the low fuel light went on and the low tire press light came on. It still runs but not that great. Anyone have this on there 09 yet? Truck has like 3500klm or like 1500 miles on it. Also found I was missing a firewall plug the other day right under the brake pedal.. Not a happy guy Going to drop it off at the dealer in the am..
Limp mode on my "06 last week. Turned truck off and all good. Went and had the codes read. #2104 and #2111. Throttle body related. Reset codes and not a problem since. In my original thread I told of a friend who had same problem but once he cleaned battery terminals,,no issue. Don't see how an '09 can have bad terminals. It's an 09 so you will be covered by dealer.
Just an update for you guys. Well it turns out it was a tranny fault. They did a reset and took it out and it runs ok. They said it was a sticky valve in the valve body and are going to replace the valve body.. So no truck till thurs or fri.. Boo.. I just hope this isnt the start of something bad .. Anyone have this done or know anything about it?
Had this happen a few years ago when the wife had a 2000 exploder. We went through 5 valve bodies on the tranny. They kept failing and the truck would go in limp mode. After the 5th one they decided to put a new trans in after I enforced the lemon law for numerous repairs and loss of use of the vehicle. Hopefully the valve bodies are made better and you wont have anymore problems. Did you truck have the hard shift from 1st to 2nd? I have that now, wondering if thats going to be a future problem. I know theres a TSB for it, Dealer gets it Mon so ill see what happens!! Good luck with yours!!
