Installing Radar Detector can I tap here?
Old 06-30-2009 | 09:41 PM
slimcubby's Avatar
About to install my Passport Radar Detector but want to be sure that all the wiring is the same as the 04-08 in my new 2009 F150. Below is a pic that I found on here and wanted to double check I can go by this setup. Its the blue wire with the green stripe.
Old 06-30-2009 | 09:52 PM
jdtech65's Avatar
I would just grab a test light and probe that terminal just to verify that it is 12V Switched power.
Old 06-30-2009 | 10:10 PM
slimcubby's Avatar
Ugh... I would if I had one of those lol.
Also, this may be dumb but how do I get the plastic covers off?
Old 06-30-2009 | 10:15 PM
jdtech65's Avatar
Can't help you with that yet. Still have a month to go til I get my 09 or else I would run outside and check it for you.
Old 06-30-2009 | 10:44 PM
yetti96's Avatar
I would skip a test light, use a multi-meter, it is much safer in these newer vehicles.
Old 06-30-2009 | 11:18 PM
slimcubby's Avatar
Ugh! My fuse box looks nothing like this picture. I am uploading the pics of my fuse box.
Old 06-30-2009 | 11:20 PM
slimcubby's Avatar
Here is what my fuse box looks like. Hope somebody here can tell me what wire to use...
Old 07-01-2009 | 12:24 AM
brlcla's Avatar
Glad to see you got the panels off. I took mine apart the other day finding where to tap for my power steps. That is this weekends project.
Old 07-01-2009 | 12:25 AM
slimcubby's Avatar
Do you know what wire I need to tap that isn't a constant 12v? I am lost since my fuse box is different than the one pictured for 04-08 models.
Old 07-01-2009 | 12:29 AM
brlcla's Avatar
Nope, I have a wire list that came with my steps that tells me which wires are the door sensors.
Old 07-01-2009 | 12:31 AM
slimcubby's Avatar
Ugh I can't find anywhere online or on this forum where I need to tap. This is bumming me out.
Old 07-01-2009 | 12:52 AM
yetti96's Avatar
I installed mine using the turn on lead for the radio. Same idea just different front pillar to run the wires.
Old 07-06-2009 | 04:17 PM
srogerson's Avatar
I can't remember which number the fuse is, but it's somewhere between like 32 - 37. If you use a tester, you can narrow down your search some with this info. I went to the dealer right after I bought my 09 for the exact same reason and had them look it up for me.
They didn't really want to help, but they did. Now my passport fires up when my truck does.
Old 07-06-2009 | 04:19 PM
cbarronx23's Avatar
On my 06 Screw, I just pulled the wires down from the headliner that were connected to the rear view mirror. There is a blue wire with a yellow stripe thats a 12v power supply that my radar detector is wired to.
Old 07-07-2009 | 06:23 PM
sharper4's Avatar
You could just use the Tapa-Circuit-Mini (http://www.amazon.com/gp/product/B00..._ya_oh_product) or the Add-A-Fuse (http://www.amazon.com/Littelfuse-FHM...gy_auto_text_b) to use the fuse box. Then your radar detector / GPS / whatever is fused and you have a clean installation without the fuss of making sure you got the right wire or splicing existing wires. They only cost $10 depending on which one you get. There are several spare fuses you could use (see page 316 I think from your manual).
