HOW TO: USB 2 to Glove Box install (no console)
#31
#32
Part #5448, USB 2.0 A Male to Mini-B 5pin Male 28/24AWG Cable w/ Ferrite Core - (Gold Plated) - 6ft
Part #362, USB A Female to A Female Coupler Adapter
#34
#35
#37
hahah i'm def. doing this mod, i hate having my ipod / wires all messy out in the open
#39
#40
First, I want to thank all that helped spread the info about this mod! This was quick & easy to do. I'm adding a few photos that other might find useful.
I had a USB/USB bulkhead jack laying around, worked fine.
My truck has the Sony factory stereo system with a speaker in the center of the dash. Removal is no different than the other setup, but be careful of the wires going to the speaker.
Here's the proper orientation of the plug while facing the dash.
I used a tie wrap to prevent a rattle, and from the connector potentially pulling loose.
The iPod showed the Ford icon, so I know it's talking to the stereo system.
I couldn't find USB2 in the menu, so finally used vocal commands to the Sync system. "USB TWO", and it immediately found the iPod.
Very cool! Thanks again!
#42
Wow, very cool! Thank you all for sharing the USB 2 mod info. I pick up my special order 2010 SUPCAB FX2 tomorrow and this'll be one of the first of many mods I do to my new tool.
I've got a question:
if you're jammin to your tunes off the USB 2 HD and your Iphone is plugged into USB 1, when you get a call does the SYNC system shut the music down and allow you to take the call...then automatically start playin the music again when you hang up??
Thanks in advance.
Thanks in advance.
#45
While I had my stereo out of mine this past weekend, I wrote down the part number of the wire running to my usb port. If I just buy one of those, will it fit in this second plug in the sync module under the dash?
Is the connection in the module, a USB-B, or a mini USB?
I want to go from there to a USB female so I can plug in my ipod, and leave it in the g-box.
Thanks for the tip. Nice write up.
