Playing with the USB on Sync
Old 07-22-2009, 12:02 PM
F150Aggie's Avatar
Talking Playing with the USB on Sync
And sure enough my USB powered Woot lights worked, got a chuckle out of it. Now I gotta see what other USB devices will work on it.
Old 07-22-2009, 12:03 PM
Barritia's Avatar
It's a standard USB port so you should be able to run anything that runs on USB power.
Old 07-22-2009, 12:52 PM
stormtech's Avatar
Is the USB port powered all the time, or only when you activate it through the NAV or voice command?
My first thought was it was pretty neat in that you could turn your lights on with a voice command.....
Old 07-22-2009, 12:55 PM
F150Aggie's Avatar
Mine ran all the time, I didn't have to tell Sync to turn on. Plus I was running another device on USB2 at the same time.
Old 07-22-2009, 06:02 PM
brlcla's Avatar
It is powered at all time. My IPod is constantly charging even when I am listening to the Sat radio.
Old 07-23-2009, 07:08 AM
iii_777's Avatar
I noticed that my passport external hard drive was lit when my ignition was off. I leave it in the glovebox all the time. Is this running my battery down?
Old 07-23-2009, 08:46 AM
BrainDonor's Avatar
Too funny. I just got those Woot lights myself.
Old 07-24-2009, 10:01 PM
d4studmuf1n's Avatar
the hardrive shuts off after a while, i noticed that on mine, but it turns off, and do any of you have to unplug the hd and then plug it back in to make it run?
Old 07-24-2009, 10:17 PM
Barritia's Avatar
I used to have to do that when i used a longer cable. i use a shortr cbale now and run the drive into my glove box and have zero issues anymore.
Old 07-24-2009, 10:44 PM
Mickeymeanie's Avatar
So using a USB splitter should work as well... hmmm... I just happen to have a spare one laying around. I'll have to see if I can charge my cell phone and play my Ipod at the same time using a splitter.
For those with NAV, are you able to load photos and/or music using the USB? The instruction book only went through loading them via CD. USB would be much more convenient...
Old 07-25-2009, 01:11 AM
Sprockettx's Avatar
Not that I've been able work out, that's for sure. Spent an hour in the 100 degree heat dinking around trying to do just that. Then again, id could jsut be me...
Old 07-25-2009, 09:09 AM
Bummer... I'll try it anyway, but I'll wait until it cools down to 95 degrees first. If I have any luck, I'll let ya' know. Based on your experience and the fact that the instruction book doesn't mention it, it probably won't work.
Old 07-25-2009, 02:31 PM
Sprockettx's Avatar
Trying to burn MP3's from USB drive to DVD now, so I can see if the jukebox will read/import them...
Old 07-25-2009, 05:32 PM
Sprockettx's Avatar
And that doesn't work either...
Old 07-25-2009, 05:42 PM
WVxlt's Avatar
Haha, awesome. Just got my woot lights in the mail yesterday. Didn't realize they'd be so noisy!
Quick Reply: Playing with the USB on Sync
